I removed the oil pan again and put in a rebuilt oil pump. I cleaned out the pick up with solvent and compressed air. Put in 10W 40W and now get a little better pressure. Thicker oil is no solution. Thanks for advice on oil Paul.
Hot 10PSI idle and 26PSI on the freeway.
By the way. Putting in shims to stiffen the bypass relief spring will get you
100PSI cold which you dont want and then the same low oil pressure hot that you had before. At least that was my experience. Removed this pan soo many times.
And yes I do have a mechanical oil pressure gauge under the hood.
Reason I have been concerned with oil pressure is after thousands to remove, get machined, rebuilt and reinstall I dont want to do it again for some time.
Oil flow for cooling bearings and pressure to keep them from contacting the crank is important especially with a 7,300lb Hearse driving up the hill where I live on this little island. Thats alot of load.
This is a daily drive too.
Hopefully 26PSI will be good enough.
Mahalo for all the input.
Ricky Jones
Ricky Jones
