Russell Schacter
Recently joined and just paid so hought I'd introduce you all to my professional cars, maybe one or both are already known to members of the club ?
Other than a few silly bits the black Eureka is a fully operational vehicle which needs a cosmetic overhaul. This car was brought into the UK a couple of years ago by a guy called James Stringer, I believe his father Eddie may have been on this forum discussing various aspects of the car which needed a massive amount of work underneath due to tin worm. Thankfully 99% of this has now been professionally rebuilt and only a minor bit of welding remains to be done to the rear of the chassis by the back bumper.
Trimwise I believe I have pretty much everything for the car but could do with a set of commercial wheels and '60 hubcaps (I have a perfect set of '59 standard wheel and hubcaps which will do for the time being), I intend to begin a full exterior and interior restoration fairly early next year.
The MM is absolutely beautiful - I bought this from a dealer in Germany last month and other than a bit of paint recification, some lighting gremlins to sort out and a gear change problem - won't change up to 3rd or 4th due the car being fitted with an edelbrock carb which pushes the TV rod the wrong way, it's complete and drives great. I'll try to sort this out asap by modifying the carb linkage.
This post is only really a quick "hello", any replies or comments gratefully received.
Russ
Russ
