Does anyone know how the side and rear rain gutters are attached? They are stainless and I dont see weld marks so that leads me to believe they are held on with adhesive. Can anyone confirm?
I know on my 75 M-M Ambulance the gutters are an aluminum extrusion. There are tiny recessed Phillps screws under a rubber cover that slides in the groove to act as a trim piece. Might be the same. Maybe dig a little on that inside lip to see if it is the same?
I don't think they are stainless but it could be a stainless cover over the steel. They would snap on place. You remove it by hooking it on the bottom just under the lower lip and roll it up and off the steel gutter.
