John Royark JR
Thats why my number didnt come up in the book. The original Carter AFB is #2862S.
Ed asked a question a while back in this thread and I don't think that anyone has answered it yet. I saw a lot of talk about carburetors, but no mention to leaded/unleaded.
Ed, you asked, "Was '73 leaded or unleaded?"
I can say for sure that my '73 Superior Cadillac used unleaded gas. I also have a '73 Ford LTD Squire that calls for leaded. I always thought it interesting that Cadillac was a couple of years ahead of Ford when it came to using unleaded.
thanks. the 73 S&S I had did not have a catalytic converter under it. it did have the smog pump same as this 68. but had been repainted so I don't know if it was labeled. it did not have the small filler neck. this is what I go by for unleaded only. now I know that the 70 we took the radiator support off did not have a smog pump on it. I have been told that only the Commercial chassis engines has the smog pump till the 73 model went to unleaded and the converter on the Fleetwood. just one more difference in the CC engines.
If a 58 coach or car has a 390 it was changed after 1959. In 58 you would have had a 365 cubic inch engine. All 390s were not the same engine. The 59-62 models are the same engine. The 1963 390 is a different engine. We found this out when rebuilding a 61 390. One of the parts came in and did not fit. The old part fit inside of the new one. Back to the parts store. They insisted the part was for a 390. We showed them our old part. When they said they just ordered a 63 part as they were all the same we knew what our problem was. The 63 390 is a one year engine. The 331, 365 and 390 blocks are the same design. The block was used from introduction in 1949 through 1962. It was bored out as needed for more cubic inches. The 1963 engine is a one year engine. The hydramatic trans was used by GM for many years. The earlier ones had no Park (P) position. You had to put the car into reverse after shutting off the engine. These transmissions had 2 Drive positions. The first or left D was a 4 speed and the right side was a 3 speed. My owners manual says to use the right side (3 speed) for driving in snow, ice or muddy conditions. Pontiac also used this trans for many years.
M.
so tell me is the 74 a unleaded fuel engine. I know that the 73 was not though it was in the standard caddy's. I'm guessing they did not go unleaded fuel till the 75 76 years.
now then the 58 we have here has the 390 not the 383. as does the 63. though they are different engines they are the same cubic inches.
got my sizes mixed up 365 was the engine I was thinking of not 383. I can vouch for the 427 or was it 429? in the 66 it was a snappy performer in the black one of Jim's.
