1970 Cadillac Superior Hearse Three Way
I get that not everyone knows the coachbuilders, but after you've had a coach for seven years, I think you should know who built your car.
Front door panels and seat cannot be original. I cannot believe that they would have built a 3-way where the front and side door panels did not match.
The car appears to be a 1970 Miller-Meteor Olympian landaulet. The factory would not have trimmed the vehicle in that manner. From what one car see, the original Miller-Meteor Regal Brocade material is still in the back. This was a 100% Nylon material that was available in blue (as seen on this unit) burgundy, gray, gold or black and was used exclusively in the Olympian models. Other models used a Nylon material called Folia Supreme that was offered in the same range of colors. Both of these upholstery materials were fairly heavy, deeply patterned and certainly much nicer than the vinyls used by Superior....which had a cheap look and feel.
70
“Needs new paint job. Some small rust spots. interior has some wear and tear but in good condition. small manifold leak (needs a clamp). Timing chain needs adjustment. small oil leak and power steering leak (very minor).”
Not in add is it has Levelizer ,The lever you can see in the pics but no mention if the rest of the components are there? Timing chain needs adjustment WTF :confused:
