1966 Superior Cadillac Ambulance
Francois,
Are you just needing the plastic lens, or do you need the frame/frames and fixtures as well?
Finding good fixtures will be a tall order. The fixture itself was a very cheap plastic and they are always all cracked up. Finding frames and lenses is not difficult.
Administrator
Staff member
If all the pieces are there, but it is cracked, it can be repaired from the inside, and then the outside could be painted for an acceptable repaired item. Problem, as Kurt has pointed out, is finding one in any condition.
