1965 Crown Sovereign 3-Way $8700
Daniel Scully
You can call 9-9 PCT. email = djscully@charter.net or PM Thanks
53,700 original miles . P/S , P/B , A/C, Auto Trans,. Power Seat,Power Table
Interior original , other than seat redone.
Factory A/C
A color you do not see too often on a coach (Sandalwood)
429 Cid ,Turbo 400 Trans.
Table Works Perfect
Ignition , Door and Glove Box Keys.
New Windshield.
New Lt Outside Mirror
Plugs , Valve Cover Gaskets , Fuel , Air FIlter Replaced
Oil change and Filter.
Runs and Stops.
All bier pins present.
No Breaks in the plastic ends on the table.
All 5 rims are the correct commercial style rims, and jack
Clear Title in my name.
On a Non Op , no back fees. If purchased in Ca
Always a So Cal Coach.
Dead paint , great chrome, stainless and bumpers
0 Rust , solid frame and body.
Needs the obvious paint.
Dash Pad cracked ( These are available in reproduction)
Steering box needs resealed. ( Works no problem just seeping )
Needs Turn Signal Switch ( Good used one comes with it not installed)
A/C complete , but not operational .
Old Tires just good rollers.
Has been sitting for a few years .
Brakes etc would have to be checked and serviced before putting it on the road.
Top of the inside door panels are toast , comes with used door tops to help in that repair.
Curtains are there , but only good for patterns.
All Curtain Rods and Holders are in place.
Wind lace needs replacing.
Load Door Glass has some scratches , needs to be polished out.
Rt ¼ trim out being straightened
Lt B pillar trim there , needs reattached
Rear load door panel , out being repaired
Seat out being reupholstered
Slight exhaust leak at rt manifold , needs gasket.
Small Tear in headliner by rear load door.
65
A few more pics.
65
Got the seat back . I'll get some pics in the AM. Found this in the seat. Cannot get the pic to rotate for some reason.
65
Got the seat back .
This is a really straight and solid looking coach and it is very attractive. Truthfully, someone should grab this one, not me, but someone should.
Seat
This what he started with. It is good on the outside but just as good on the inside. All new foam , padding and any repairs needed to the springs or frame etc. Can not tell you how many jobs I have seen that he has redone from other shops half ass work.
