Brendan Martin
Matthew: I have a 63 MM and the old drums stop her just fine. Just my 2 cents (does that buy else anything anymore??).
I echo this statement. My 63 stops well.
all of this is not to knock you or your intentions for the car. as I said it's your car and you do what you want. my suggestion would be to start as I do when I get a new car. get it cleaned up good and running first and drive it around some to get the feel of what it needs. just cleaning it out lets you find a number of things you never knew about the car. what goes where and how it works. then get it running. nothing worse then a dead horse in the shop for me. then drive it around sum. that for me is the fun part that first run around the block and tweaking it back into reliable mechanical shape. once you there you will have a clear idea of what the car needs and whether or not you like it enough to put the money into it. mean time you can be locating and gathering parts. forming your plan of attack.
now me I lover the looks of that 63 the superior was a striking body once back together. I just hated driving it. I could not get in or out without striking either my head or knee on something in the door opening. but man I loved working on it. once you got your head around superiors construction techniques and accepted the car for what it was knowing you could do a little better in reassembling it, it was a joy to work on.
so what i'm encouraging you to do is get to know and trust your car first then take it apart.
Mike, a lot of ambulances and combinations were built with suicide doors. Why would Superior build it that way? Because the customer was buying it that way.My question is ..............why would Superior built it with suicide doors if it was a combo and no 3-way table ??
I don't know anything about it, never seen a combo with suicide doors before.
thats why I'm asking
When you get some time, take a look through this thread; you'll find many combinations and ambulances - hightops as well as lowtops - with C pillar door hinging:
Front spindles are the same from 1961-1969 Cadillac.
Stock disc caliper parts from 69 bolt right on. (69-73 rotors)
Add proprtioning valve and move flex lines from back of drum to front of rotor
New vacuum booster and master cylinder.
(Drum brake wheels don't clear front calipers)
Now why would a customer order it? Some just liked the look I suppose. But the only reason I've heard is that it allowed the stretcher to be loaded/unloaded through the side doors if there was some reason why you could not use the back door. It was said this was in case of a rear-end accident, for example, or if the back of the ambulance was somehow blocked in at the scene of an incident. To me, it sounds like an irrational fear, but to the folks in that era, apparently that was a reasonable request.
