Aloha
The ¾ ton (GMC?) rear end on my 1962 Eureka Hearse is failing and I want to swap it out for a rear end that is the studs to axel type not the old truck type that mine is that has the drums pressed onto the hub with the wheel studs. If there is a ¾ ton truck late 60s or early 70s like a GMC 2500 that will fit right in that would be less work and cheaper for the shop to do.
Anybody did a swap? What rear end? Please give me your advice and ideas.
Mahalo Thank you Ricky Jones
