Bill Marcy
Nicholas, congratulations on this ambulance and the fabulous job you seem to be doing. I say "seem" only because I am far from an authority on such things as finding period-correct bits and peaces. Truly, my hat is off to you!
Do you recognize where the knob on the right came from???
Paul,
Don't say early '60s Chrysler, because it is not. They are very similar, but not the same. If you want any of the '60-'64 Chrysler knobs, I have many that you can have.
Dan,
'62 what?? Is that a Dodge radio?
Doesn't the '61 Cadillac Chassis Manual show the exhaust system for the commercial chassis? Every '61 Cadillac pro car had the same exhaust sytem, regardless of conversion company.
for the 63 of Brendon's we really want to save the flooring. it was in similar shape. I sanded the floor with 80 grit paper on the DA and followed up with 180 then 400. and finished it as you would a new floor. it worked out will. of course to do so ad get it even one will have to remove all the raised trim. you will need to clean it up and polish it anyway.
As always, thanks for the update. When that wood is restored it will be really something.
I did as Ed describes with the 52 Pontiac linoleum, though I did not go down to 80. Very slow and gentle got forty plus year old stains out and it polished up beautifully.
Might want to have second thoughts about sanding that Linoleum flooring as a lot of that contains Asbestos.
That exhaust location is pretty scary too. No way would I have an exhaust outlet under the passenger compartment of any vehicle.
This is from the Superior parts catalog.
