And the same goes for the green 58 DeSoto...
James,
That is a beautiful DeSoto!! (which one are you referring to, as all the images in this thread are beautiful) It is a Dodge based DeSoto, with the smaller chassis and Dodge front sheet metal. And it also started life as a 4 door sedan. You can tell by the higher fins, and also where the fins start. I forgot to mention earlier that the station wagon bodies have fins starting behind the rear doors, where as the fins on the 4 door sedans/hardtops start in the door itself. They did it this way to allow for the different Chrysler/DeSoto and Plymouth/Dodge doors on the shared wagon bodies. I do note that the DeSoto conversion above has custom squared off window frames on the rear doors, instead of the rounded ones on the factory doors.
if it is a National it will be clearly labeled as such. they were vary good about badging there stuff. every one of them will have a name tag on the right front foot well. they would build on anything you brought to them also. probably the biggest aftermarket manufacture to do so.
very interesting that chrysler offer a factory ambulance. I had not heard that before it does add some to the mix. if there is no other badging on the car and the factory tag is complete if may be a factory car. without any inside pictures one would not know if they put in a divider in or not.
Ok since we are all here discussing this topic in such depth I think it would be rude to email the images to just one or two individuals and not post them here for all to see and learn.
Brad, you posted these images and I’ve looked at them and studied them in depth
After looking at the images (above) which you provided I feel I can now try to identify the 1957 Chrysler Ambulance picture I have. I’m assuming the image I have is of a 1957 Chrysler Windsor Town & Country Station Wagon Ambulance with a raised roof. As I doubt they started with the more expensive New Yorker Town & Country model, but they might have… I’m no expert so you might be able to look at the image and know what station wagon model it is.
Also added options were tunnel lights in the front and marker lights (or whatever they’re called) on the rear roof. Not much cutting just basically adding a higher roof and rear door was all they did to the car.
This car was in fact manufactured by National Coach Company of Knightstown Ind. In this case the client actually purchased this as a station wagon and then drove it up to Knightstown for National to do the conversion.
National did not make very many Chrysler chassised ambulances in 1957 and this particular ambulance might be one of just a few produced. Someone else might have the production numbers on these National Chryslers for the 1957 year model but they were very few as national focuses primarily on Chevrolet and Pontiac’s. Therefore it goes without saying that this is indeed a VERY rare ambulance (as is this very rare image of it, which has never before been published or posted on line until today.)
Here is what Coach built has to say about the 1955-57 National models.
“Most 1955-57 National funeral coaches and ambulances were built on Chevrolet and Pontiac donors and were offered for the first time with a choice of two head-rooms and two wheelbases (standard plus a 30" extension). High headroom models were available with a choice of an awkward looking bi-level turtle back roof or the more attractive raised roof that gently sloped down to the top of the windshield. Chrysler- and DeSoto-chassised coaches were also available for extra cost, as were Buicks and Oldsmobiles.”
Source: http://www.coachbuilt.com/bui/n/national/national.htm
Image below is the 1957 National Chrysler (Windsor Town & Country Station Wagon???) Ambulance
_________
Now regarding the 1958 Desoto, with the information already posted in this thread by all parties, I now lean towards it being a 1958 Desoto sedan conversion with added side door trim that I see on the station wagon models. Since I am still unable to see or understand the difference in the tail fins (height & size) all I can go on, is the fact the fins start in the middle of the door. This is why I will say it appears the conversion started out as a sedan. Brad what do you think?
However what is interesting is that this particular car looks different than a Memphian and I have highlighted the differences I have noticed and numbered them. Here is the image below with the numbered issues clearly marked which I notice are different.
1. The side trim is what I see on other station wagons is this correct?
2. The rear passenger door is straight at the top and not curved like you car has.
3. The rear side quarter window has a different angle to it opposed to the Memphian
4. The roof drip moldings end horizontally at the top of the rear quarter roof and do not curve downward like the Memphians do
5. The placement and size of the rear window and the roof drip moldings curve downward a little
6. No “Memphian” name badge is on the front fender and this car is new at the time so it’s a good chance it’s not a Memphian and I also don’t see a Comet badge either.
Here the image without all the red circles and numbers so it can be seen much clearer
You’ll also notice the actual door frames around the windows are not as “thick” or wide as the Memphians, or maybe it’s just the angle or lighting??
This image below you can see the fin and taillight assembly better as well as the size and placement of the rear window on the back door.
After giving it some thought and knowing the same man purchased both of these ambulances new it is very possible that the 1958 Desoto is also a National. I’m just assuming here but he might have been so happy with his 1957 National Chrysler that he decided to also buy a 1958 model with the same optional tunnel lights and marker lights but in 1958 decided to use a Desoto instead of a Chrysler Chassis. This would also explain why a “Memphian” or “Comet” badge is not clearly seen in the image. When I speak to him I will get clarification and then post the findings.
Hope this helps a little and if in fact the 1958 Desoto is also a National it too is a VERY rare ambulance.
Chrysler DID NOT BUILD a factory ambulance, however they were sold exclusively through Chrysler/Plymouth/Dodge/Desoto franchised dealers.
In addition to building plain wagons Chrysler continued to offer it’s ambulance conversions in both the Windsor and the New Yorker Series. The cars were available on special order through Chrysler dealers, but there is no record how many were built. This is the New Yorker version.
Ed
The images I posted are of Nationals, Brads car however is clearly not a National or he would have easily seen the builder plate and would not be asking, therefore its basically a process of elimination for him.
Brad where are we in the elimination process regarding identifying your car?
we know its not a National, no builder plate?
we know its not a Memphian, no badge on the front fender
we know its not a Comet as there is also no badge on the car
what else can we eliminate ???
I'm just asking because I really don't know,
Who built the ambulance conversion then if Chrysler didn't?
the quote in the book leads one to think they did,
Economy Coach became Memphis Coach in 1955. They weren't two different lines, one succeeded the other....Now, I've seen that Memphis Coach and Economy Coach are mentioned together... was Economy a cheaper line that Memphis offered?
