There was someone that was selling exactly what you are looking for about 2 weeks ago. Surprised that you didn't buy it when you have been looking for this part for over a year now. I think that it was sold. Pontiac and Cadillac are both the same, or if not, very similar, and I doubt that anyone would know the difference.
http://professionalcarsociety.org/forums/showthread.php?t=20600
No, they are definitely NOT the same, as Bill already knows.
They are not the same as all the options were not the same. This car should have a rear fan switch and the center done light switch. Maybe rear ac. It would not have the push button for the safety latch as the doors open from the rear. The switches would be the same for the controls. Not knowing if the poncho has the rear ac or not the first task would be to find what wires did what put the nessary switches on them and cut a aluminum plate the size of the impression . Bor the holes for the switches and the screws and cover the hole while you look around for the proper superior plate. You may never find one but fill the hole and having thinks work will move the car in a better direction.
I know just for difficult is is for you Bill to do these things. If you can cut a cardboard the right size use a ice pick to punch the screw holes in the courners pull the correct switches off the ambulance plate you have I will make you a switch mounting plate . Or just send me the ambulance plate with the cardboard template and let me know the switches you need in yours. The switches use a different size hole that is why the other cover would need easer to use for a pattern. You can get the correct hole size and spacing from it. It will lack the scrip and scroll work of the superior one but how many of them you see that had the warn off paint covered over with lable maker tape
Even if it isn't the same, at least it would have covered the hole. Something is better than nothing.
I would be wiling to bet this is what your looking for and the front hole would have a chrome button i it.
