it took some doing but I final was able to gather a few lenses in glass for the 53. they are 4 5/8 so not a common size. they use a reflector and replaceable bulb with a trim rig holding it all together. what I discovered but accident was the older tractor lights were that size as were the Harley police bikes.
so the question I have is should them be a clear spot lens or the cut pattern lens. the pattern I have are fog lights so they would show flatter and lower rather then a spot.
they use a 32 watt bulb with a rather wide filimant
