I remember Jack Pinner describing how if the found a panel truck in a yard they would cut the roof off with a cold chisel and take it home. the raised roof in the panel was use in there high tops. will I don't have a high top but I see some of the handy work here. the first is with the flash the second with out. you can see were they welded the tops togather about 6 inches back from the curl. I get it back on 4 wheels and the top striped I can show you the other side.
