I know this is a stupid question, but I got a new m/c and I cant see where you add the fluid. Anyone know, I know this is going to be a nightmare bleeding this set up:argue:
Is there a filler somewhere higher up on the firewall that gets plumbed to the master? '54 and '55 at least had a filler on drivers side firewall and line running down to the master under the floor.
on my '54 and '55s that filler is bolted to the firewall and goes down to the master that is mounted to the frame under the floor. I'll take a look at the '57 in a couple of hours and report back. This is one in a '54 circled in blue
Optional. So we ve determined that that is the m/c fill up tube I jusy need to connect it somewhere. Im redoing the brakes. New m/c, wheel cylinders, brake lines
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
