WTB: SUPERIOR Nameplate
James Fischer
Looking for SUPERIOR name plate for back load door should be about 4-5"wide....if anyone might have an extra and would like to sell...please contact me...thanks you !!:smileflag:
Sorry, I should have also inquired about interior or exterior name plate. Not too familiar with this year range. Two parts car possibilities that may help you out.
Going to a junkyard with this unit Wednesday, day after tomorrow. I'll buy part if there.
Then next month, heading back to property with this unit:
Atilla,
It should go on the OUTSIDE of the rear door....the 72 Superior Parts Book says its part "
#375107-Nameplate-SUPERIOR OUTSIDE"........1972 Cadillac Superior Highroof.
Also,I would be interested in the top sidemarker lamp/housing on the second unit......:smiley3:
Thank you !!!
did your 72 ever have a superior emblem on the rear??? the 71 I had only had the dealer sticker there. and I don't see any name plate tags showing up till sheller globe corp took over superior.
Ed,
The 1972 Superior parts and repair manual gives a part # (see previous post) and also shows it in the lower left corner of the rear door.......:smileflag:
so find me a picture of one. can't every car have it left off from. it may have saw been only used on a crown.
This should be the 'elusive' Superior badge desired, which may or may not have been utilized in a different location
71 I had. It was in the same spot.
This should be the 'elusive' Superior badge desired, which may or may not have been utilized in a different location.
That is the one Attila !!
I remember it being on a 1971 Cad Superior Hightop.....back in the day....
I worked for "Superior Ambulance" and everyone thought the owner was crazy to have "those little plates" made for his units......little did they know !!:smiley3:
THANK YOU for posting !!!
one of the glue on fall off ones. I have not seen one on a car other then the sheller globe ones that look similar. jog my memory again was the 72 year a Earnhardt built car?
