Windshield replacement
Where to get a replacement windshield for a 1965 Pontiac Superior? It is a few inches taller than an OEM replacement, and since the upper opening needs repair anyway, I’m thinking it makes sense to make the opening shorter so an OEM windshield replacement can be used instead.
None available new unless you find some new old stock. NAGS # is DW678 fits all coachbuilders who use commercial glass any builder from 65-70 will work. Good used ones are out there.
The stock glass only fits on the bottom. They are tapered as they go up. So there narrower at the top. The only way to do it would be to cut the opening out of a car and graft it into the pro car hole. Hopefully some one will jump at the chance to be the only one with new glass soon.
