Window Felt?
I know I'm putting the cart before the horse here, but I'm trying to think ahead. Where in the world am I going to find the felt seals that go in the door window track, along with the lower rubber window sweep at the bottum of the door windows on my Superior? As far as the quarter windows, and rear loading door window, they apear to be basic window gaskets that shouldn't be to hard to match up. I'm sure someone has replaced these. Thanks in advance for any help you can offer.
Thanks guys. Mine aren't in to bad of shape, but would rather go ahead and replace them if possible. Plus, I just bent one a little, one of the screws broke and I didn't realize it, and when I went to pull it off it hung on the end and bent it a little, but could stil be re used and not very noticeable. I got a Steele Rubber Products cadilog around here some where, but can't seem to find it. I've heard Rubber the Right Way is a better company, and has a wider selection, but have never bought anything from either of them yet.
you can get the run Chanel from any one of the venders. they are stocked in different sizes so you need to know what yours is. same thing with sweep. the but trust me you not going to find the side and back glass grommets anywhere. treat them with reverence. use a lot of wd-40 on them befor you try to remove them. the nice thig aboutsuperier is they are a reversable grommett. you can put the right one on the left adn vice verse to put a fresh side out. and reversethe backglass if it's not to hard.
Rubber the right way's prices are slightly less than Steele, I ordered much of my window felts/fuzzies/cat whiskers and sash channels/channel rubber from them and have worked out really well.
