Washington fender well mounts
it turns out that I need a set of fender well mounts for the Washington cot hook. I was told that the ferno one was the same but I see its not. anyone one got a set of these out there .
mounts
You need mounts and the complete up-dated bar that came out in 1965. I have to complete sets i bought a few years back. I will look tonight and let you know. I want to make sure everything is complete, before i sell them to you, if you are interested. I will pm you back later:4_11_9:
definitely interested in the mounts that fit the Washington bar. it's going in my 53 Barnett so a 63 up date would be a lot newer. I got a couple Ferno-Washington bars that fit those mounts. I'm looking to use the Washington bar with the Washington cot I have. any help would be appreciated
I may have a set, but they are stored with my coach. If you don't locate a set sooner, I'll contact you when I get my coach out of winter storage.
found them they just aren't mine. so here are what the mounts look like that I need for the Washington cot bar.
I'm affraid those are not the ones I have. Mine are a little bigger than the standard F/W ones most coaches have, but they are not closed on one end. Also the ones you show look like they are made of heaver metal. Sorry.
Jerry
a little wider is all they have to be to work. I haven't seen enough of them to know if they made a number of different styles. I don't think a ferno bar would stay in these.
