I take it they feel that they need the wheel opening in that case any 71-76 would do as the all take the same skirt. you would need about 4 to 6 inches around the opening to have enough to marry it together.
Looks like a section from the body side molding down would do it. A coupe would be probably better but I think a sedan could work. it don't look worth doing a full 1/4. Don't discount a section off of another pro car. call this place, a Cadillac only yard. When I was there they had pro cars, series 75, coupes and sedans. Tons of clean rust free sheet metal
i sure would not replace a whole quarter for that. much easier to just weld in the corner that is missing and any 71 to 76 will do for that. or is there some under that white that should be changed? did it take off the skirt mount and the lower chunk of the wheel well also?
My body guy found a southern quarter, Soon will be back in business with fender repaint and doing the back door as well. I am pretty excited. With all these cars farmed out I am down to two cars, the Pinner and Poncho.
if there 20 years old they are OK. bet that set I put on back of the suburban were at least that old. the 15 year old and up stuff have such a thin side wall you pick one up and it feels like you could poke a finger right threw it. the new bias ply are the same. but they don't have that heavy steel belt to heat up and breakaway.
Talk about tires Fred Kanter (Kanter Auto Products) drove his 1951 Packard Patrecian to the Packard meet in Reading Pa. from Boonton NJ on the original wide whitewalls. Car is original never restored very low miles. Fred said he did it just to prove old is better. Think he got home OK the same way.
