Wanted - Outside Door Handle
Need a rear door outside handle for a 1969 / 1970 Miller Meteor. The correct handle will be on the left side (drivers side) and the hinges are on the right side (passenger side). This is the typical door hinging for Miller Meteor.
Thanks
Paul
There is no way to know exactly what GM branded vehicle that the handles were sourced from, and there is no part numbers casted into the inside of the handles. There is no doubt that the handles were used on some other GM vehicle, but only extensive research would reveal that information, and I don't know of anyone that has ever undertaken the project of determination. The Miller Meteor parts book indicate the original GM part numbers for some components, however, the outside door handles are not listed with a GM part number, only the Miller Meteor part number, which is of no use today, other than to distinguish handles from year to year.
All pictures will help, and a picture with a measurement is always best..
the 72 cb has a diferent curve. I have one of them here. it lacks about a 1/4 inch from bolting to the front. there is the standard GM tabe on it that woun't let it go into the big hole also. but the spacing is the same.
