Wanted: ECM module for 80-84 Cadillac
Mike Burkhart - Deceased 1948 - 2016
December 30, 1948 - October 21, 2016
WANTED: ECM module for 80-84 Cadillac with 6.0 engine. The module is about 4"X6" and about 1" thick. It is screwed on to the drivers side inner fender by 2 screws and has 2 pigtails, one to the distributor and the other to a wiring harness.
Any help is appreciated.
Thank you,
www.rockauto.com
</SPAN> Related Parts1980 CADILLAC DEVILLE 6.0L 368cid V8 4BBL (6) OHV : Electrical : Engine Control Module (ECM Computer) WikiPriceCoreTotalA-1 CARDONE Part # 774670
Reman. A-1 CARDONE Engine Control Computer; Does not include PROM
$79.79$0.00$79.79ACDELCO Part # 21811778 {#19109029} Remanufactured
MODULE,ENG CONT()* Non-stock item--shipping delayed up to 5 business days$110.79$28.80$139.59
The actual name of this part is "Electronic Spark Control" or decoder. GM Part #16010366. It is NOT the module that goes inside the distributor. It is external and bolts to inner fender.
Paul, I will check out the info you gave. Thank you!
