So my '67 sedan DeVille is having transmission problems. Once up to speed it feels fine, but from a stop it almost feels like it has a stall convertor in it. it feels like it's slipping and when you accelerate a little harder it'll sometimes slam and then act as if nothing's wrong. I've heard of these trannys having a sump issue where the sump slides out of the transmission enough to lay on the pan and cause a similar situation.
Anyone had similar problems? The car has only 46,000 original miles but I think this transmission is baked.
The next question is will a transmission from a 1969 472c.i. Cadillac interchange with a 1967 429c.i. Cadillac? One option is to just do a transmission swap for now is why i'm asking. I'd like to learn as much as I can before dropping the transmission pan. I do know my transmission can have one of 2 filters/sumps... 1967 was a transition year and 2 filters/sumps were used... an "early" style which looks similar to an engine oil sump and the "late" style that is the more flimsy, flat filter-type. I don't have the pan off yet to determine which I have. The fluid is full and isn't scorched, so i'm guessing the front pump or torque convertor are giving up if it isn't a sump issue.
Any suggestions/comments? Thanks!
