Time for inside over haul
I tore put all the carpet and speakers from the inside of my ambulance .... Found some parts I'm not sure what they are .... Be nice I'm new . I am in need of some period specific pictures of the inside of a 66 miller meteor ..... Any and all help would be appreciated ....as you can see from pictures radio station wasn't very kind to the ambulance ........?
The hooks are for hanging a cot from the ceiling. They look just like the ones in my '77 MM, so they must have used the same style for many years.
Kurt
inside
Here are some pics of the inside of a 67 M&M. I'm not sure where these Pics came from Most likely old ebay stuff. hope this helps.
inside over haul
Here is one of my 70 M&Ms
This one is set up with an unusual overhead cabinet
Bruce Biancalana Photos
Here is a 69 M&M of mine, it was messy inside when I took these, I don't believe it was mine yet. Hope this gives you some Ideas. Interesting thing about this car is that the floor was ordered in Formica, another option vs Linoleum flooring.
Go to whatevere hardware store you have near you. They should adhesive removers for carpet glue. Try a small section of the floor first.
darn now I got to go out and look. did I put the hooks in backwards in the 69 the interesting part to be is how they did or there have been redone differently on the door jams. I don't think two of them are painted the same way. as for saving the linoleum don't give up to quick on it the pattern runs clear threw and you will be surprised how much you can sand out of it. little corner damage can get hidden or ignored if the main part of the floor is intact. nothing makes the car look correct as the right flooring.
had to check it out I got the hooks in right first time for some things I guess.
