I can't reach the data plate for a pic right now, but here is the info on it:Should be a tag on it somewhere with serial and model # Can you get a pick of that. Do you have all the hook up leads with it? The 4 gauges are easy hookups for checking vacuum, volts and rpm. The 4 th measures air to fuel ratio and would have a lead that goes in the tail pipe. The scope part I would look on u tube to explain what the ignition patterns look like for diagnostics. They all work together to give. an overall picture of the engine.
Thanks Dan.
If nothing else, it looks cool!I have seen them that covered the whole wall. Impressive to say the least. But still didn't tell you any more the a few hand gages.
