As to your video:
No, it appears that you might have an incorrect flasher in the socket. Flashers are rated for the number of bulbs that they will flash. Pull the flasher out of the fuse panel, it is located in one of the four corners, and looks like a small metal rectangular metal box about 1" x 3/4". Once you have it out, check the number of lamps that is marked on it. You will need to count how many bulbs in the front and rear stop / directionals you have. For the directional signals, you only count the bulbs on one side.
Systematic Check for Problems:
Lets start from the beginning, by check that all bulbs are illuminated with the parking lights in the on position (first detent of the headlamp switch). They should all be illuminated, and bright. Then have someone step on the brake pedal, and the stop lights should illuminate even brighter than the parking lights. Once you have confirmed that these two circuits are working properly, start the car, and activate the 4 way flashers. All 4 corners should flash together. The 4 way flashing system uses its own flasher, and it is usually located under the dash, near the steering column, in its own special holder. Turn off the 4 way flasher, and try the directional, one side at a time, and check to make sure that both front and rear are working. If they are not, and all the previous tests were OK, then the problem lies in the directional switch. That will require professional assistance, since the steering wheel needs to be removed to service it. If the car has a tilt / telescopic column, then special tools are needed to service the switch. It is a difficult job to do the first time, but gets easier with experience and the proper tools.
Service Procedure when you don't know where to start:
Start by shutting off all power to the vehicle, or disconnect the negative battery terminal. (Ambulances usually have a master disconnect switch for the 2 batteries.) Using a plumbers 1/2" socket wire brush, that is available at most hardware or big box stores (i.e. Home Depot plumbing department), remove each bulb, and insert the wire brush, and give it a couple of revolutions, until the inside of the socket is clean and bright. Blow out all debris, and then coat the metal end of the new bulb (part #1157) with a light coating of Vaseline, and insert it into the socket. You will notice that there is one high and one low pin on the sides of the bulbs. Make sure that these pins are properly aligned, and give the bulb a slight twist till it is fully seated into the socket. If the bulb is loose in the socket, you can give it a gentle squeeze with pliers, just enough so the bulb fits securely. Do this with every bulb socket. Wipe off any excess Vaseline that is on the glass part of the bulb. The Vaseline will help keep moisture out of the bulb sockets, and maintain a good ground. Report back after you have done this project along with the rating of the flasher and the number of directional bulbs on one side of the car.
These type of electrical gremlins usually happen when a car sits in the garage for weeks or months on end, without being used. Repairing the way that I have suggested will help to eliminate storage problems for the future.
