paying out the noise for some one to chase down a electrical problem or dumb luck. way better to have some dumb luck. this 96 did not have any interior lights working when it came up from other things in the paper work it looks like it's been some tine since they worked. the hole for the fuse was empty. the ohm meter showed a short. the first fuse I put in looked like a flash light and went out with a bang. the second one stayed till I rotated the knob on the light switch the it went pow. no replacing the light switch did not cure it.
with 6 light over head 6one in each door 2 in the rear view mirror and the home link on that one fuse plus the relay, were to start. I was sitting in the drivers seat so start there go back to Acubuilds splice. we got lucky the second thing with screws I took off has the standard screw threw the insulation problem. no luck like dumb luck.
we unplugged the visor and robed a fuse out of the avalanche and we got lights. the home link even works. a little shrink wrap and a shorter screw and we are good to go. the lesson is do the simple checks first. that's usually the problem
