Warmed up a bit today, so I decided to have a look at the electric window motors in my rear doors. The windows are VERY slow and when it is below 50 degrees or so, need help to raise to the full up position. Ultimately, I would like to put new motors in, but having never done that, it is a bit intimidating. Also, the Fisher body manual I have scares me when I read that you NEVER take out just the motor, as there is tension on the spring and serious injury can result. It says to take regulator and all out together, clamp in a vise and drill a hole that goes through both regulator arms so a screw can be put in there to hold the tension on everything and THEN take off the motor.
I guess the questions are: How in the world do you get everything out like they say through that small hole in the door? Everything that moves in there is dryer than a bone--should I try to lubricate everything and see if that helps before I do all of this, and if so, what should I use? Would it just be a whole lot easier to have a regular auto window place do the job? Below, a pic of the door, with motor showing on the bottom just left of the large hole. (no, that is not rust at the bottom front, it seems to be some sort of spray adhesive stuff that is rust colored) Thanks for any suggestions.
