(1962 Cadillac Superior Combination)
OK so I have used two cans of PB Blaster, pulling by hand, slide hammer, heating center with a torch, screw-type hub puller (broke it), porta-power cable puller. I even tried to rattle it with a flat air chisel while puller was on it.
The rear brake drum WILL NOT come off. :bonk:
I am afraid to put too much heat or pull from anywhere outside of the wheel studs. Anyone have suggestions?
Please never compromise your safety. Cinderblocks are not safe to use even as a secondary sure way to fail. I have recovered many injured people and unfortunatly a few bodies from under vehicles up on non-wood blocks. Take the time to do it right, or you might not get the second chance to enjoy your labors.
