Kent Dorsey
PCS Member / Funeral Director
So the rear of the 2007 Eagle is lowering itself after sitting for awhile, when cranked it slowly rises up to it's normal heighth. Took it to local mechanic, he was a little unsure if this required some type of commercial suspension/motor or standard Cadillac. I wrote Mike Kellerman who responded: "It is my understanding that there is a unit underneath the car that is a factory unit and it's no longer available. If you could find this unit, that would be the best way to to fix it, but if not, you could buy an aftermarket air compressor with a switch. You could have a mechanic install it by connecting the air compressor to the factory air bags. You would be able to adjust the height up and down using the switch...".
I went through this issue with the 1996 S & S that now resides with Sean Meyers, I fixed the issue and 2 years later it did the same thing. At that time, the option was given to convert to standard coil springs, which is what I did.
On Ebay, there is a "Rear Air Suspension to Shock Coil Spring Conversion Kit for LeSabre Lucerne", that according to the compatibility list, has "Rear 2006-2011 Base Hearse 4 Door" listed.
Just asking the mechanically inclined on this site is that sounds like it will fly on this 2007 Cadillac.
