Rear 1/4 Glass ID
Daniel Scully
A little tough to measure do to the shape any ideas? Thanks
they are a side glass out of a early 50s 4 door. they used the 3 piece back glass. but what one I can't say yet. here is a mopar I looked are when I had the 63 superior apart.
Get a piece of poster paper and lay it over the window, cutting along the edges of the window with a razor blade or exacto knife while holding the paper tight against the glass as you go around. After you do the first side, you can tape the paper so it doesnt move as you go. When you are done, you will have an exact template of the glass that you can measure OR put on another piece of glass to see if they are the same size.
Glass
Ed,that does look pretty close.These came from the Paul Nix sale and I thought it could be for a pro car something. But could be a oem part that they just used for 1/4 windows. Shawn,s idea would also help to get a better idea of what it is.Thanks
most of them have a number in what would be the lower corner. bu ti can't remember the code it has to do with the standard the glass meets and the year it was cast. seen them in lof ppg and hurculite. a good guess is 5 to 10 years older then the pro car they are in. for the pro car they just flipped it over and put it on the other side. I did the paper template and I could not match it up. on the 63. here was a close as I got for it.
