Where is the radio itself mounted?Thanks to Tony Martin for the beautiful restoration completed for the 52. Wired in, and includes a functional speaker.
Response times will shrink significantly.
All I see are the control head and speaker. Does it not have a separate chassis (often mounted behind the driver's seat in a procar, or in the trunk of a police car)?Steve, the locations are as above.
I believe the car was originally delivered without an am radio, and it was added by Dr.Roger White.
If you want to have the original looking radio that will receive both AM & FS stations, look into having it converted using the Auroa radio mounted inside of your radio case. On the outside it will still look and function like a factory radio and have modern "guts" on the inside. https://www.tech-retro.com/aurora-design/home.html There are 2 installers in Canada, or if you want to send the radio to me I can drop it off the the fellow that did the change over on my 1962 radio. I dropped it off at Fall Carlisle and picked it up at Spring Carlisle (PA) swap meet. That saved me shipping both ways.Ed, sadly no, though not that much left to listen to on AM radio up here.
Bill, Tony's work is absolutely first rate.
