I was reading my book that came with the new radiator for the 92. it mentioned a condition I was unaware of begin a problem. electrologists due to a poor engine ground. the picture looked just like this one. back in the days before computers the ground cable was always attached to the engine block. this new stuff I guess is different. found the ground it was attached to the stud on the thermostat housing. when I took it off everything was clean and shinny. but when I removed the nut holding the housing on the stud came with it both sides the nut was rusted tight and the stud was close to the same condition. nether side would have a vary good ground . when I went to flush off the radiator the top set of fins melted in the water stream. see a lot of bad stuff come threw the radiator shop but nothing like this. so check those grounds out there you people with newer cars.
