Email for more info/pics. >>>Do not PM as inbox is near capacity.<<< Am making one more parts drop in next couple weeks for pick up in Hudson. Some prices are very firm while others have a little wiggle room.
PayPal fine. Buyer responsible for shipping costs (not included). [*] means those parts are not in hand, nor priced yet. Will remove on my dime if needed. Included recently sold elsewhere.
'55(?)-'58 Superior dash pod - Used in ambulances and combinations that holds auxiliary lighting switches. Plastic with a high mortality rate. No cracks. $85.
'59-'62 Superior dash pod - Similar footprint as above, slightly different shape, no cracks. This one also differs by having a back lit strip across bottom with switches labeled. $85. *May fit '63-'64 as well. Sold.
'59-'64 commercial outer windshield stainless moldings - Perfect shape. Probably going to kick myself later for selling these. $275/set.
'59-'64 Superior rear loading door glass - 2 available. $300/each. 1 sold.
'59-'64 Superior jump seats - 3 pair left available: blue/gray, gray/gray, and red/white. Complete with partition hooks and extruded aluminum floor molding sets that go around opening. Conditions vary along with prices, $250-375. Blue/gray set has an additional cast aluminum decorative molding that I may remove and keep. Not often available loose.
'59-'64 Superior door panels - Blue/gray. Decent originals to use as-is or for patterns if missing; not perfect but not torn up. $300/set of 4 including all original aluminum moldings. Matching rear compartment partition and wheelwell panels, $60/each including all original aluminum moldings. Front door panels sold. $150/rear pair.
Late '50s-early '60s heater with cover - 2 good non-leaking units available. Used in both ambulance and combination rear compartments. Not coach specific. Superior mounted vertically above/behind rear wheel, Miller Meteor mounted horizontally in subfloor. $90 for heater and two piece cover. 1 sold.
'61-'62 Superior quarter glass - 2 pair available. $290/pair. Will split for $175/each.
'63-'64 Superior quarter glass - 2 pair available. $290/pair. Will split for $175/each. 1 pair sold.
