I had to pull the carb as the float sank again. took a radiator out as it was leaking and thought as long as it's down this far I might as well overhaul this thing setting here. so I did the used car overhaul. it's a true pro car decide to do one thing and you have to fix 5 others to do the one. but bare wires broken ends and the bolt to long in the ground strap latter. new hoses and thermostat plus retainer ordered. we are ready for the the carb again and the radiator when it gets repaired. then we can go around the block some more. we must be getting some were opened the back door and we got lights now. never had them before. wounder if I can get them bullet lights to fit. now that would be cool.
