No Reserve: 1960 Cadillac Eureka 3-Way Hearse on Bring a Trailer Not mine
Daniel Scully
Site Supporter
This 1960 Cadillac Eureka hearse is finished in black and powered by a 390ci V8 paired with a four-speed Hydramatic automatic transmission. Equipment includes a vinyl front bench seat, reverse-hinged second-row doors, an alternator conversion, Wilwood front disc brakes, and steel wheels with polished covers. The car reportedly spent time in Wisconsin before being acquired in California by the seller in 2010, and service performed during current ownership has included installation of a replacement engine, an overhaul of the steering system, and a replacement exhaust system, engine wiring harness, fuel tank, engine mounts, ignition wires, shocks, and brake components. This Eureka hearse is now offered at no reserve with service records, spare parts, and a clean California title in the seller’s name.
https://bringatrailer.com/listing/1960-cadillac-eureka-3-way-hearse/
The body is said to have been repainted in its current shade of black some time ago, and the rear bumper has reportedly been re-chromed. The left floor panel was replaced during current ownership, while holes are noted in the right floor and sheet metal is missing around the rear wheel wells. Bubbling is evident around the door edges, trim is missing from the right-rear door, and rust is also said to be present in the front inner fender liners as well as around the rockers. The wipers, reverse lights, and right wind wing assembly are inoperable. Spare inner fender components will accompany the car, and photos in the gallery detail various finish imperfections.
Steel 15″ wheels with Cadillac-branded covers are mounted with 235/75 Diamond Back whitewall tires, and the seller notes the rear wheels are affixed to the hubs with metric bolts. Wilwood disc brakes have been fitted up front. The shocks were replaced in 2016, and service performed since 2018 has included an overhaul of the steering system as well as a replacement brake booster and master cylinder. A spare booster and dual circuit master cylinder are included in the sale.
The bench seat is trimmed in black vinyl, and the cabin features matching door panels complemented with gray carpets and a patterned headliner and visors. Cracks are evident on the dash and steering wheel, the shifter indicator panel is missing, and an air conditioning control panel has been fitted to the dash. Photos detailing wear on the interior surfaces as well as corrosion and a missing dash insert are viewable in the gallery. According to the seller, the analog clock is disconnected, the rear window is hazy, and the heater blower, parking brake release, high-beam switch, and interior lighting system are not functional.
The horizontal-sweep 120-mph speedometer is said to be inaccurate, and the seller notes erratic auxiliary gauge operation. The five-digit odometer has rolled over at least once and currently shows 8k miles. Around 31k miles have been added by the seller, though total mileage is unknown.
The rear compartment is equipped with tan privacy curtains and two-tone side panels. A replacement chrome-finished casket loading table tops the storage area, which can be accessed from both sides of the vehicle. A spare casket table frame and motor are included in the sale. Photos showing torn and faded upholstery as well as corrosion on the metalwork are included in the gallery, and the seller reports the sliding table motor is inoperable and the mechanism is missing components. Signatures from actor Felix Silla and surf-rock band The Ghastly Ones are present on the right-rear door.
The replacement 390ci V8 was sourced from Engine Components & Machine of Santa Ana, California and has been fitted with ceramic-coated headers, a Waldron’s exhaust system, a Gener-Nator, electronic ignition, and cadmium-plated hardware. Additional work performed during current ownership is said to include rebuilds of the carburetor, radiator, and oil pump, along with a replacement water pump, battery and cutoff switch, engine wiring harness, PCV valve, fuel tank, fuel temperature sensor, Cunifer fuel lines, engine mounts, and ignition wires. Exhaust scent is evident while driving, and a fuel leak is noted by the seller.
Power is sent to the rear wheels through a four-speed Hydramatic automatic transmission. The rear differential was rebuilt in 2016, and the seller states stainless steel transmission oil cooler lines have been installed. The frame has been reinforced around the front suspension mounts, and additional photos showing the condition of the underbody are provided below.
https://bringatrailer.com/listing/1960-cadillac-eureka-3-way-hearse/1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_9bfcdcc7-9bc4-4fbc-8b97-ed...jpg1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_904b29c3-7ca8-495e-92e0-e9...jpg1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_84c391ba-0a17-4aac-b673-91...jpg1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_3da3a44f-3420-47c3-8e47-ed...jpg1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_06e1b8b0-3b69-4a08-9f57-f3...jpg1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_50ad212e-5d71-4a54-9ad9-28...jpg1960_cadillac_eureka-3-way-hearse_1960_cadillac_eureka-3-way-hearse_d91ede60-ddb6-4b1f-8ed0-c0...jpg1960_cadillac_eureka-3-way-hearse_6-Feet-Under-House.jpg
