I took the Lifeliner in for some exhaust repairs this morning. Turns out I had a leak where the "Y" pipe comes into the exhaust pipe to the rear and leaks at the exhaust manifold outlets.
They had to cut out and replace about 18 inches of pipe on each side from the exhaust manifold outlets but to my surprise, there are no exhaust donuts. The pipe has to fix exactly right and bolted in place. Also had the smaller leak welded close.
While it was on the lift searching for exhaust leaks the gas line from the fuel pump was leaking and had that replaced as well.
Now it is quiet as a church mouse getting closer to being ready for Akron 2011.
