Darren Bedford
I bought a new rad for my car from a parts shop in Michigan when I was there for a couple car shows a month ago.
Today was a nice sunny day. No wind and warm enough to work outside.
I took out my old original rad and matched it up with the new replacement rad that was suppose to be a exact match rad for a '73 CC Cadillac.
For the most part it was. Here are some noted differences:
The original had a 45 degree bend up on the lower rad hose pipe. Replacement was just straight without the rise up.
The replacement had the upper transmission hole about 3 inched lower than the original. Luckily I had a copper transmission line that was able to flex out of the way and be re-attached in the lower hole.
The upper rad hose tube, the overflow tube, lower transmission line hole and the heater hose tube were all in the correct locations.
The thing that is worse about the replacement rad... it is thinner with it's plastic end caps than the original with brass tanks.
The replacement rad needed a 1/4" shim to get snugged up.
What I did was cut two pieces of the upper rad hose, that I was replacing anyway, and used that as the shim.
It worked perfect and the rad is in there nicely now.
Another thing that doesn't look so nice is that the top of the rad is just a grooved piece of aluminum, not a flat solid top like the original.
Doesn't look right and I'm sure it will be a trap for dirt.
The card that was in the box with the rad is in the photo below.
It says EXACT FIT ! it fit but far from exact fit !
Check out the photo. I guess it is shiny and new and the car is running again so all is good.
Don't believe everything you read or have been told by a counter guy.
...but enjoy the drive !
Darren
Darren
