The only thing that I see is that you are missing the rubber bushing, which you can make out of a piece of rubber hose. On the bottom of the shaft support (small hangy-down thingy) is a locking screw. Loosen it, push toward the column, and then tighten it. Then insert a small screw into the hole and attach it to the windshield pillar. That part supports the shaft.
