Daniel Scully
I had these originally made with tabs to set in the sign bracket to raise them up due to the dip in the name plate. So to make them more universal I cut the tabs off and a friend made me adapters . If you need you slide in the spacer bracket and they clear. The Flxible had the pin type so we made some adapters for them also. Rather than multiple holes and holders this makes it easy to use the signs in just about anything. Some of the sign plate holders are tall but even those where close sometimes using these name plates.
