Jim Staruk
I tried Windex, stainless steel pads, Fantastic and "Stainless Steel Magic". The trim around my windows is still dull and blotchy. Is there any solution to my sad stainless steel blues? Thank you - Jim
is it stainless steel or aluminium . the 66 is aluminium and has been coated . the coating is what was dull on it.
on the superior the up rights were aluminum and the top and bottom trim stainless steel. a magnet will stick to SS and not the rest. it may not hold good but it will stick. if it plated normally it's base metals or pot but they can plate aluminum to. what I found on the 66 superior was that the aluminum was coated with a heave clear coat. and that it had started to work lose giving it a cloudy look. on it I sanded it off and polished it back. one can rub a little metal polish on by hand and they will shine right back up. what ever thy used to coat them with was a vary hard product. almost like a power coat. it just never lasted the 50 years. I was going off the top of my head and I think the divider molding on the b pillar is aluminum to
