Exhaust System 101, Air Intake Silencer
Resonators are for the control of exhaust noise just like the muffler is in the exhaust system. My 2005 Ford Freestar has one. I would suggest a couple of options.
Option 1] If your car is going to sit for long periods of time between start ups or is going to be run on short runs only where the exhaust system won't be getting up to and staying at operating temperatures for at least 30 minutes, or if you already like the way the exhaust system sounded, DO NOT install one. It will just be a collection point for moisture that the engine generates and will eventually rust out. As the engine is run, water vapor is produced as a by-product of the combustion process. This moisture collects in the cooler parts of the exhaust system, namely the muffler and resonator. Since the muffler is closer to the engine it will heat up faster than the resonator. That leaves the resonator as the last place for water to collect and since the resonator is at the rear of the car and
pro-cars are longer than normal passenger cars, the temperature of the resonator and end of the exhaust system will be the last to heat up and expel moisture, thus resonator rust/rot out.
Option 2] If you like an extra quiet-sounding exhaust system, or you want your car to be original as equipped from the factory [if you know for sure that it came with one installed], or you drive your car for long distances
every time you start it [and just don't let it idle after you start it and then shut it down after so many minutes every time] and the exhaust system gets to operating temperature and stays there, INSTALL ONE. This is all based on preferences,
your preferences on how you want your car to sound when running.
Do what you decide to do. This information/suggestions are FYI only, not recommendations. Also if you fall into the Option 1 group, you
might want to consider a stainless steel exhaust system, it is expensive but will last a lot longer than regular steel exhaust piping or as Paul posted earlier, if your not going to keep your car forever, then go with regular steel exhaust system.
Not sure what's in front of your air cleaner but by 1974 [73 for Cadillac], GM was putting a duct that connected the air cleaner intake to the inner fender in a attempt to silence throttle/carburetor noise [especially at WOT] and draw cooler intake air from outside the car than from under the hood as had been done for many years. I think GM called them a
silencer and they had used them in the 80's on their diesel-powered trucks and cars. I'm not aware that GM had put them on cars in the 70's but you just never know...
Hope this helps.....
Don
