Jeremy D. Ledford
PCS Volunteer Chapter President
The Lifeliner run on its own for the first time today! Took some work getting there. After doing the mystery oil soak on the cylinders, new coil, points, condenser, starter swap, fuel pump and two fresh battery's I got her fired up today and running on her own! Will have to swap out the carb again due to a choke issue with the one running it now. Didn't get in gear due to low transmission fluid and I didn't have any on hand ether. Will swap the carb out (again) tomorrow and add trans fluid and see what happens then! Meanwhile here is a video and update! Probably the first time this car has ran since about 1990!
[ame]http://www.youtube.com/watch?v=Nc9-FPJuCx0[/ame]&
