Donor field Superior. Trial and error.
Thick aluminum side supports bolt to inner framework of rear loading door below waistline; 3 on each side. Rusted solid, can't reach backside nuts either.
Glass held in by 3 inner aluminum moldings; one upper, and vertical side pieces that fit into larger outer. 5 accessible screws on upper came out. 6 accessible screws each vertical side running from outer into inner, all heavily rusted, only 1 of 12 came out. If only one vertical inner molding is removed, there would probably be enough room after cutting/removing glass rubber molding to finagle window out since upper aluminum is already off. Not happening. Crap.
4 rusty bolts on upper outer aluminum structure secures body panel above window. They aren't budging either. Crap.
2 small Sawzall cuts takes off tops of aluminum frames and body panel along with. Progress. Now to slowly, carefully, remove rubber molding and slide glass upward... This is how far glass made it before binding hard.
Although curvature wasn't same from top to bottom, removing rubber allowed for full width of window track permitting *just* enough room that it should have sufficed.
Now who is paying attention why this didn't work??? Didn't cross my mind until this point.
