I got asked today how to take off the springs on a hood hinge. hard to describe as I just take them off. never though it was anything. getting so getting up and down now is more work then anything else. but here is how I do. remove hinge then go get vice grips with the big curve in the jaws. clamp the jaws tight together around the rear hoop of the spring. pliers should be loose on the spring. put both feet against the hinge the pull the spring to the top. you have to move it 1/8 of a inch to get it out of the slot and its off.
