Help Needed- Unity Door Post Spotlights
I need to know the "K" shaft length to order lights for my 1968 M-M Classic 48. Assuming driver and passenger side would be the same length.
Unity was able to supply all the other information on the mounting brackets and other parts. Just need the shaft length to place the order.
The holes are in the door posts, the original ivory colored handles are there, but no shaft or spotlight head. Trying to put back what was there originally.
Thanks
Can Paul or anyone advise if the '68 would be the same as on my '70? I would assume, since the windshield is the same, that the post should be the same, too. True?
If so, I can measure the spotlight shaft length on my '70 for you. Not today, though.
I spoke to Scott earlier today, and gave him the information that he was needing. Just for the record, the shaft length for the 1965 - 1970 commercial chassis cars is approximately 7 1/2" exposed or 8" when removed from the handle and spotlight head shaft. This is what Unity calls the K length.
The correct Unity spotlight bracket part number is 11L (left) and 11R (right). When it comes to spotlight brackets for commercial glass cars, the guide that Unity provides is for standard glass passanger cars, and they were not privy to what the body builders were using.
