Help identifying '60 Buick
Could someone please identify this coach? I realize it may be difficult due to the snow. We could not locate any coach tags. We did locate GM tag with style, body, trim, paint, and accessory information. Also have VIN#. Where might coach tags be located? We plan to go back in the spring? Thank you.
Definitely not Flxible. D pillar and rear loading door window dictates this much.
This is the only '60 CB Buick shot I could find without corner windows. Notice D pillar shape is quite similar. Side window trim is all wrong however.
Moving on to a National Chevy, D pillar again similar and side window treatments closer.
This '59 National Buick looks closest. Granted, D pillar window angle isn't identical - but note huge roof line difference from A to B pillar, like the one you've pictured.
Finally, note that this '59 National Dodge's partition window's angles, trim, and shape aren't like your '60 Buick.
Although I can't find anything that matches exactly, my guess still goes with National. Side window treatments are too close.
man I could use a jump seat that looks like them. you common builders put there tags usually on the firewall. the most common builders off a Buick in 60 would be Flexible and Comet. I'll give you a little hint. put a leaf rake in the car cut the handle off so it will lay flat in the trunk. you can clean off a car in a hurry. here is the only pictures of the 60 flexible inside I have. it was snagged off e-bay a few years back. if it is a notional they all were tagged on the divider panel passengers side just like the eureka. people would lose the out side emblems but not the inside ones
Looking at the pics that Atti posted, the embossing on the compartment doors in the 59 National Dodge looks like the same embossing that I found on the compartment doors in the 60 buick.
