Exhaust Replacement
In my experience yes. The Y pipe and the tail pipe, muffler have been the same. You can use the intermediate pipe but some were in there you will have to get another 40 inches of pipe. Depending on the location of your muffler.
Thanks, so basically a Fleetwood exhaust starting at the engine manifold to the tip at the back would work, with the addition of the extra length for the commercial chassis, correct?
If you want the car to be quiet, then you will need to add a resonator to the end. Most aftermarket systems don't include the resonator because the younger generation want you to hear them coming and going.
Should have put a Super Chief on the roof instead. It is louder than a Q!
