Exhaust Question - 76 Cadillac Commercial Chassis
I hate noisy cars, and my car is becoming one of those........
I think I may have to bite the bullet and seriously think about replacing the exhaust Manifold gaskets. The more I look at it the bigger the job seems to be. There is already one bolt that is broken and is causing some noise issues.
This is not a Job I can take on myself, so I will have take it to a shop.
Before I do, what are your thoughts about the scope of work to get this done?
One of those you never known jobs. What ever you do be sure and have the mating suffice of them plained. As they tend to warp which is why the bolts brake. Ask first about doing that before the work starts. So there is no confusion. Double gaskets will blow out on the first road trip. And be prepared for the possibility of them needing to remove the head.
There is only one way to do this job properly: disconnect the exhaust pipe from the exhaust manifold, then remove the intake manifold, then remove the heads. The heads will need to go to a machine shop to remove all broken bolts and plane the manifolds and manifold surfaces. Since you are halfway there, you might as well have the engine rebuilt, because just doing the manifolds will cost about $1500 US in labor. I had this done on my 1969, at 70,000 miles, and after I sold the car to Gene Smith, he lost the engine on the way home because the oil pump failed. The engine looked fine from what we could see on top, but the oil pump was below and gave no indication of its impending failure 2 or 3 years later. You can check with Jasper Engine for what a complete rebuild is going to cost, and have your local mechanic remove and reinstall the engine.
