Ed, I Know you are out there so, help me out with your opinion. I hear misses at the tail pipe when the coach is running idle. I know from the mechanics inventory that she found dwell variation when my tune up and diagnostics were done. So far, to smooth the the idle, I have been burning 100 octane and that helped a lot to smooth out the idle, but there is some missing that I can faintly detect. I have also given the coach BP 93 octane it seemed to run well each time but still with the miss in the tailpipe. So where do you think the primary cause is of the miss. Dwell variation can be caused by worn distributor shaft and/or a worn timing chain that has some miles on it, (81,500.00) also to some degree the exhaust can trap unburned fuel that accumulates in the header section of the pipe some time and reignite so I have come to understand can happen. Cheap fix scenario here now and I don't want to do alot to solve the problem. I'll do a rebuilt distributor, If I can isolate it or I'll do a timing chain and gears if I can determine the problem is there, I know some people change out there point to electronic. How can I fix it the most economical way to clean up the idle?
